gear reduction starter to fit 52 JD A
florian
03-14-2007 18:27:46
Does any one make a gear reduction starter to fit a 52 JD A? Thanks
Josh Wilhelm
03-17-2007 18:42:03
 Re: gear reduction starter to fit 52 JD A in reply to florian, 03-14-2007 18:27:46
The 52 A starter is on the bottom like a 60. I don't know of any starter that fits in the bottom. You can get gear reduction for top mounts. Just use your stock one have it rebuilt. But run two 12 volts and run 24 volts with the two bateries. Thats no different than using a 6 volt starter and pushing 12 volts through it like lots of people do. This should give you plenty of power.
champspa
03-15-2007 15:05:40
I think a Cummins starter will fit, one for a 5.9
