oliver 77 puller
Ed Hodge
03-13-2007 17:40:50
im building a oliver 77 for pulling i put a 770 motor in it for the house power with 3 3/4 high comp. pistons im useing 770 cam and head with lots of work looking for more idears on what to use.
need. the big 770 intake and a 1650 gov. does anyone have on????? ?
neattapuller
03-17-2007 08:44:09
 Re: oliver 77 puller in reply to Ed Hodge, 03-13-2007 17:40:50
Ed where do you pull?
Ed Hodge
03-17-2007 11:53:53
 Re: oliver 77 puller in reply to neattapuller , 03-17-2007 08:44:09
i live in Connecticut. i try to pull all over the state
neattapuller
03-18-2007 10:35:17
 Re: oliver 77 puller in reply to Ed Hodge, 03-17-2007 11:53:53
you should read the rules before you start saying what you have in your tractor your illegal in the antique pullsAll parts of the tractor must be stock and from corresponding model
and year prior to 1956 and within manufacturers repair tolerances. No
frame modifications will be allowed, such as the altering of wheelbase,
etc. Replacement parts from alternate manufacturers are acceptable.
All tractors are to have a working muffler. Tractor owner is responsible
to supply documentation from manufacturer.
Ed Hodge
03-18-2007 14:29:34
 Re: oliver 77 puller in reply to neattapuller, 03-18-2007 10:35:17
the rules you are telling me are for a club i dont pull with!!!!!
neattapuller
03-18-2007 18:30:26
 Re: oliver 77 puller in reply to Ed Hodge, 03-18-2007 14:29:34
you did last year
Ed Hodge
03-19-2007 04:14:33
 Re: oliver 77 puller in reply to neattapuller , 03-18-2007 18:30:26
if i pull the 77 it going to be in the hot stock class with connecticut state so it wont be cheating. my super 88 i pulled is all stock unlike uther peoples tractors in that club. i like block pulling better so u wont see me there to much this year seeing how you know me so well who are you????
neattapuller
03-19-2007 15:29:27
 Re: oliver 77 puller in reply to Ed Hodge, 03-19-2007 04:14:33
why are you nervous you will be caught?
Ed Hodge
03-19-2007 15:48:39
 Re: oliver 77 puller in reply to neattapuller , 03-19-2007 15:29:27
no. i dont pull with connecticut state that much i pulled 2 times last year. so its no big deal to me like i said i like block pulling more.
neattapuller
03-19-2007 18:05:32
 Re: oliver 77 puller in reply to Ed Hodge, 03-19-2007 15:48:39
thats where those rules came from antique tractor.org they are the group that does the block pulls they do most of the fairs
Ed hodge
03-19-2007 18:29:37
 Re: oliver 77 puller in reply to neattapuller, 03-19-2007 18:05:32
my grandfather started that club i know the rules by heart no one cares that much in that club as long as its stock apearing.
i getting sick of your B.S. you still havnt told me who you are
neattapuller
03-20-2007 05:17:06
 Re: oliver 77 puller in reply to Ed hodge, 03-19-2007 18:29:37
lol
770
03-14-2007 13:58:28
A true 770 intake is the same runner size as a 1550. Also, A MS tsx 755 is almost identical to the MS tsx 903 on a 1550. What is a 1650 governor going to do? Does it fit and why??? What RPM"s and class rules do you have?
Ed Hodge
03-14-2007 15:36:52
 Re: oliver 77 puller in reply to 770, 03-14-2007 13:58:28
we have a rpm rule 10% over stock theres more lugging power with a 1650 gov
770
03-14-2007 16:30:35
 Re: oliver 77 puller in reply to Ed Hodge, 03-14-2007 15:36:52
These are just MY thoughts, so take them as such....On one of my 770's I took .030 off the head and gave it a good port job. Kept the valves the same size, just because it only runs about 2100 rpm. It gave me a 7 horse increase on the dyno. 3-3/4 domes, which power seal doesn't make any more, were always good for 10% more horse. Dist. springs always seemed to help. 1650 gov??? I guess I just don't understand that one. Good luck pulling your Ollie, let us know how you do!
Ed Hodge
03-14-2007 17:23:03
 Re: oliver 77 puller in reply to 770, 03-14-2007 16:30:35
1650 gov. has more lugging power then stock 770 and little more rpm i put one in my super 88 and it works well
J Schwiebert
03-13-2007 19:07:36
I went around with another puller last fall, a 77 and a 1550 use the same cam, what all do you call lots of head work>
Ed hodge
03-14-2007 15:41:16
 Re: oliver 77 puller in reply to J Schwiebert, 03-13-2007 19:07:36
lot of porting work took .100 off the head biger valves
JDH
03-13-2007 17:46:45
Use 1550 manifolds and carb. and cam. Keep your eye on ebay. every now and them ypou may get lucky.
