Govener Questions
Redneck6030
03-08-2007 13:34:03
When people talk about getting the most RPM's out of your govener and getting more- i was wondering how you would do this, i allredy know about the heavier spring but what else.
Redneck6030
03-08-2007 14:02:31
 Re: Govener Questions in reply to Redneck6030, 03-08-2007 13:34:03
where is the bolt your talking about on the govener?
Thanks
ChadS
03-08-2007 14:13:35
 Re: Govener Questions in reply to Redneck6030, 03-08-2007 14:02:31
If its a Farmall governor, its located inside the governor, (behind the cover) its the bottom bolt where the spring linkage hooks to. You can back it out and gain a little, not much, the spring tension, and the lighter weights is what gets the higher rpms. Too short of spring, and it wont idle under a grand,,,, The right spring, and you can get 2500-3000 rpm easy and still idle low enough to count it firing. Chad
ChadS
03-08-2007 13:48:05
Take the weights out of the governor and grind bout half the material off em. The stop bolt will control where you set the high rpm to, make sure the spring is a heavy one. Chad
