Turbo for 1466
Redline Fever
03-08-2007 12:06:11
im buildin a 1066 for tractor pulling i jus got done puttin a dt466 on it and ive been told i should change the turbo instead of useing the t04 thats on it i should put a 3lm on it does anyone knw anything about these and where can i get one? and another? is should i go with the 18.4 that are on it or buy a new set of 20.8's radials?
MJD123
03-11-2007 18:45:37
 Re: Turbo for 1466 in reply to Redline Fever , 03-08-2007 12:06:11
If your farm stock is like mine then you will need a 13 mill.pump and some.93lines and 4 hole .24 injectors bare min. Then get you some worn 20.8's and go have fun. Have pulled against 1066's set up like yours and the days of just opening up the pump and going to the pull unfortunately are over!! The "farm stock" is gone. Good luck!
P.S. you should be able to get these fuel systems pretty reasonable as there are a lot out there.
856 puller
03-08-2007 18:48:32
the 3lm is a good turbo ours made 45 lbs boost. they are not the best but good for the money and can be modified for more performance
ejr-IA.
03-08-2007 16:22:45
Just how much did you do to the 466?pump,lines,etc.If you have some good power Id go with the 20s.In our 3000rpm class all that can be used is a 3lm 466.Take a look at www.spencer diesel .com for info on turbos ,look under IH 1486 to see some turbos updates.
Redline fever
03-08-2007 19:55:29
 Re: Turbo for 1466 in reply to ejr-IA., 03-08-2007 16:22:45
welp for now ive got my pump and lines off my 414 on the 466 cuz i cant run the inline pump in the farm stock and im limited too 3'000 rpms also.. so what should i do 2 my pump and where can i get bigger lines and injectors at do i need them?
L.D.W.
03-08-2007 21:54:44
 Re: Turbo for 1466 in reply to Redline fever, 03-08-2007 19:55:29
RF, shoot me a email, I can get you settup with a lot better charger than a 3lm for a very good price. Larry
