chads or other farmall people
Kevin
03-08-2007 08:39:51
Alright, for quite some time now ive been thinking about a 221 from a 460 in an H. I know that is posible and apperantly not that hard of a swap. I was wondering if a 282 diesel would work in an H just as easy as the 221?
sflem849
03-11-2007 19:10:22
 Re: chads or other farmall people in reply to Kevin, 03-08-2007 08:39:51
I LIKE THE DIESEL! Go to pulloff.com and get some parts to build it and then you would really have a smokin' good time.
MJF
03-08-2007 13:07:53
Is that the same for a 301 in an H too
ChadS
03-08-2007 09:22:03
Parts needed:
460 flywheel
460 pressure plate
Super H clutch disk
H pilot bearing
H starter ring
460 rear engine plate
460 frame rails
460 front timing cover
The only part you need to alter is the flywheel. You must cut the area where the starter ring sets, down to the H specs and put the H starter ring on the 460 flywheel. Other than that, it is a bolt it deal. ChadS
