max bore for 820 830
dieseljdpuller
03-07-2007 20:18:24
What is the max bore anyone has heard for an 820 or 830 JD? I am using a stock block and will be ordering custom pistons. Thanks!
skip33652
03-08-2007 17:16:40
 Re: max bore for 820 830 in reply to dieseljdpuller, 03-07-2007 20:18:24
I have heard of some boring the blocks to6.5" .375" over like thet have been doing to all the R's for years I think that would be okay as long as you ultrasounded 6.375" maybe to be safe .don't have a clue who to get pistons from though.Paul
hahter
03-08-2007 15:54:16
The factory max is .125 over. My father and I pull with a 56 820 modified tractor bored out .125. since the rod journals are hollow so I would not recommend stroking the crank.
Terry
AJD
03-09-2007 10:11:58
 Re: max bore for 820 830 in reply to hahter, 03-08-2007 15:54:16
why not stroke the crank? there is one around here 10" a stroke. runs real good!
hahter
03-13-2007 15:27:18
 Re: max bore for 820 830 in reply to AJD, 03-09-2007 10:11:58
You are already running 16-1 compression ratio. Also as I stated the crank journals are hollow and can break the crank. You a running with a time bomb if you stroke a 820. Just my opinion.
