tire grinding disc
super_m
03-05-2007 19:08:38
how many tire grinding disc does it take to top cut a set of 15.5's?
Drew
03-05-2007 19:45:25
 Re: tire grinding disc in reply to super_m, 03-05-2007 19:08:38
I have found that an electric wood planer works better than a grinder for the tops of the bars. The rubber comes off in ribbons instead of powder. Work on several bars at a time so when one gets warm you can switch to another. Use carbide blades rather than HSS blades.
DWO
03-06-2007 14:35:36
 Re: tire grinding disc in reply to Drew, 03-05-2007 19:45:25
We like to use soapy water and bristle brush before each pass with the planer. Cleans to preserve blades and then helps to cool.
Andy in IL
03-05-2007 19:43:49
Do you mean how many top cuts can you do with a cutting disc. I borrowed a 4 inch disc to do a v cut 14.9 top cut a 15.5 and a 16.9 and the guy I borrowed from had the disc for at least 10 years and it still cut like mad! These dics are not cheap so consider the one to do all!
