Vaccumn pumps
Shaggy
03-03-2007 20:27:08
I was talking to a guy that pulls a truck and he was telling me about running a vaccumn pump on his engine and how he gained 30Hp by using it. Do you think this would have the same effect on the tractor motors? Granted the tractor is turning less RPMS but some have more CID than his truck does. Just curious.
Shaggy
buickanddeere
03-05-2007 06:27:18
 Re: Vaccumn pumps in reply to Shaggy, 03-03-2007 20:27:08
You would gain more power by knife edging the crankshaft, blocking some of the oil drain back holes and running a dry oil sump.
G/MAN
03-04-2007 13:09:34
Is it going to produce a benefit? Probably. A measurable one? Hard to say. Vacuum pumps are used on high-end, all-out performance engines in order to get that absolute last little bit of power out them. Generally by guys that think nothing of spending an extra $1000 to gain another 10 horsepower. Using the vacuum pump to evacuate the crankcase gases and drastically drop the crankcase pressure helps the rings seal better and increases cylinder pressure. You mentioned more displacement, but the much higher engine speeds and probably much higher compression ratios those all-out engines run will result in much more blowby and crankcase pressure than a bigger, slower-running engine with less compression. If you use an arbitrary number and say that a vacuum pump is worth a 2% horsepower gain, then a 1500 hp engine would see another 30 horsepower - kind of like the engine you mentioned. A 75 hp antique tractor engine? 1.5 horsepower. Worth the trouble and expense to install? I guess that depends on how bad you need another 1.5 horsepower.
Shaggy
03-04-2007 15:31:28
 Re: Vaccumn pumps in reply to G/MAN, 03-04-2007 13:09:34
Thanks I was just curious to see what some you guys thought.
Thanks again Shaggy
