Max farmall H bore
Farmall H Bore
02-26-2007 11:12:50
I was wondering if a farmall H block can be bored to 3.75" without using sleeves. I have heard conflicting reports, so if someone could clear this up I would appreciate it. Thanks
ChadS
02-26-2007 16:00:37
 Re: Max farmall H bore in reply to Farmall H Bore, 02-26-2007 11:12:50
3.75,,, no problem. 3-13/16 is max bore and still run on the block for H's. Use a 350 head gasket,, should be big enough to seal up without rings filling the counterbore. Chad
