Unstyled A Axle Brgs
JPatton
02-24-2007 11:39:26
I need a set of outer axle bearings for my 1935 A. My parts book shows the number to be JD 7245 R. The John Deere parts site says this number is not valid so I am assuming that the part is no longer available from John Deere. Does anyone know where I can get these bearings? Does any one know the actual bearing number that I might use at the parts store or bearing distributor house? I would even consider a set of used bearings, felt seals and retainers if anyone has a set.
Thanks
J
Herc36A
03-05-2007 18:26:24
 Re: Unstyled A Axle Brgs in reply to JPatton, 02-24-2007 11:39:26
I see this is kind of an older post. That bearing is still available from Deere. The number you need to ask for is JD7245. (drop the R on the end) Deere shows 25 of these in Milan, IL rite now with a List Price of $44.50. I have been selling Deere parts for 15+ years, let me know if I can help.
JPatton
03-05-2007 18:35:18
 Re: Unstyled A Axle Brgs in reply to Herc36A, 03-05-2007 18:26:24
Herc36A
Thanks for the reply. I did get that info from the John Deere board a day or two later. I will check them out.
Thanks again
J
JDGnut
02-24-2007 12:48:23
Try typing in the part number with no spaces.. but it came up Obsolete.. but try this dealer.. the show to have one...
HILLSBORO EQUIPMENT, INC. HILLSBORO WI 608 489 2275
1 - 3 24FEB2007 JA LOCATOR SHOWS OUR NEW AND USED PARTS - CALL FIRST
JPatton
02-25-2007 07:01:24
 Re: Unstyled A Axle Brgs in reply to JDGnut, 02-24-2007 12:48:23
JDGnut
Thanks for the reply. I also got some help from P Browning and Duane Larson over on the John Deere board. You guys are the best.
J
