pistons and block
Rob Hills
02-23-2007 06:45:43
how do i get the piston out of the block for a 51 jd b
blockhead
02-23-2007 07:50:17
 Re: pistons and block in reply to Rob Hills, 02-23-2007 06:45:43
Remove the rod caps from the rods (inside the crankcase), then either pull the block/pistons/rods, or push the pistons out the front once the head is off.
Rob Hills
02-23-2007 08:08:36
 Re: pistons and block in reply to blockhead, 02-23-2007 07:50:17
thanks im on that step now and i can push the pistons right?
blockhead
02-23-2007 10:37:00
 Re: pistons and block in reply to Rob Hills, 02-23-2007 08:08:36
You can, but it's about as much work to just pull the pistons/block/rods all in one step and then pull the pistons out when you have it on the bench. All that stuff has to come out anyway.
Rob Hills
02-23-2007 11:00:38
 Re: pistons and block in reply to blockhead, 02-23-2007 10:37:00
thanks
dboll
02-23-2007 10:05:37
going back together is alot harder than coming apart, If you are struggling now it's probably going to get worse. I would go get an I&T manual!
Rob Hills
02-23-2007 10:58:01
 Re: pistons and block in reply to dboll, 02-23-2007 10:05:37
ok thanks
