case engine build up
jdfan1
02-22-2007 08:26:02
Hi I just purchased a case 830 gas for pulling. I want to get more power out of it but want to keep a stock appearence. I heard you can use case 870 diesel (336 cubic inch) sleeves after boring the block and Moline G-1000 pistons to make it a 336 ci gas. Is this true? Are there easier ways of getting more cubic inches? Thanks!
joecool
02-24-2007 15:19:24
 Re: case engine build up in reply to jdfan1, 02-22-2007 08:26:02
find a propane version, steel the head, put BIG card, and go. is it a case-o-matic? these are very tuff, the more weight you can hang on it the more they like it.
dboll
02-23-2007 05:01:36
cheap stroker- offset grind the crank from 2.748 to 2.5 or 2.25 and use farmall rods, I would save up and put in 1 to 1.5 inch of stroke
ejr-IA.
02-22-2007 15:23:02
Know a puller that took a 377 and made a 504 which is a 6 cyl. useing the 45/8 M&M piston sounds like what you want to do only 4cyl.Hey just add another inch to the crank and make it a 403cid
johndeereman
02-22-2007 15:18:25
you want more power paint her green and yella just kidding i have a deere and a case
