flywheel and starter
unstyled a jd p
02-18-2007 16:13:49
how do i put a starter and flywheel on a unstyled a for pulling. what size starter should i use. where should i mount it.
Larry Baker
02-20-2007 03:46:13
 Re: flywheel and starter in reply to unstyled a jd puller, 02-18-2007 16:13:49
what i read is true
we pull a's also
we also have parts that you need
check our ad in green mag
frieght might be a problem if you are far away
the new starters work awful well
Rusty Junk TX
02-19-2007 03:54:47
In addition to the previous replies: If your tractor is hopped up a little and the Delco 12 volt starter from that era will not spin it over very well, you can bolt a starter from most 6 cylinder Deere diesels right to it. I run a JD Nipondenso Japan starter on mine. 528cid unstyled A and it spins her right over. One of the small, light gear reduction starters off the almost brand new big Deeres fit also. There are probably many other starters that will fit that cover bracket and work as well. They have kept that pattern all these years. Marcus
Mike n Mo
02-18-2007 17:39:35
The easist/best wat to do it is to get an electric start flywheel and crankcase top cover/starter bracket from an early styled A (1940-1947)(sn 488,000-584,000). You can use a stock starter for the same era, use it on 12 volts and it will work just fine. Check with your buddies in your area or salvage yards, the parts shouldn't be difficult to locate as there were a number of electric start A's from that era. Mike
02-18-2007 17:52:36
 Re: flywheel and starter in reply to Mike n Mo, 02-18-2007 17:39:35
JPatton
02-18-2007 20:01:15
 Re: flywheel and starter in reply to unstyled a jd puller, 02-18-2007 17:52:36
Take a look at the styled tractors that had the angle iron frame. '39 to '47. Those that have electric starters had them mounted on the top of the crankcase right behind the governor and right in front of the steering shaft support. Hope this helps.
J
02-19-2007 18:04:38
 Re: flywheel and starter in reply to JPatton, 02-18-2007 20:01:15
but my air intake for the trasmosion is in the way
