Wheel width and traction
J.D. Clark
05-01-2002 11:06:41
I am going to be getting new rims put on my tractor that I pull and use for farm work. It is a JD that has the double bevel rims that can be put on in eithor position. Right now the wheels are really narrow, and i would like to widen them out a bit. Would it affact traction at all if i put the rims on the inside bevel to widen the wheel base, or should i leave them on the outside one and move the centers out? I really don't want to move the centers because I know how hard they are to break loose. My thinking is that it makes no difference, but I figured i could get some good thoughts here. Thanks
Andy
05-02-2002 09:04:13
 Re: wheel width and traction in reply to J.D. Clark, 05-01-2002 11:06:41
I have seen them run both ways, but I like to run mine on the inside bevel, and move the wheel in, so you don't have all the weight and stress on the end of the axel, that's my thoughts.
Jack
05-01-2002 14:15:09
Yes,go ahead and move the rim on the cast center.It won't hurt your traction a bit.I had to move my cast hubs and wheel bevel rims on my 70.The cast part with the adjusting bolt can be a real pain.Good luck with yours.Jack(TN).
