Cam Question for Drew and WTW.
Zeke Miller
02-10-2007 06:31:55
Who would you guys recommend for grinding the cam on John Deere A with a power block and heisler head combination?
Drew
02-11-2007 19:57:05
 Re: Cam Question for Drew and WTW. in reply to Zeke Miller, 02-10-2007 06:31:55
I get my cams Murphy's Motor Service (573-696-3655). You may also want to look into a set of high ratio roller rockers. I saw an increase of 4 hp on a 60 w/ +.125 M&W pistons @ 540PTO speed with the rocker arms.
DPG
02-12-2007 07:37:03
 Re: Cam Question for Drew and WTW. in reply to Drew, 02-11-2007 19:57:05
Drew,
Was the 4 hp with the improved cam or without?
Thanks!
Doug
Drew
02-12-2007 10:38:04
 Re: Cam Question for Drew and WTW. in reply to DPG, 02-12-2007 07:37:03
Stock cam and 2.0:1 rockers gained 4hp over baseline.
Reground cam and stock rockers was 5hp over the baseline.
I havent dynoed the reground cam with the 2.0:1 rockers yet. Im waiting to get a power block finished up and installed with another head that has some work done around the eyebrows and the valve guides worked on to allow more lift.
DPG
02-12-2007 14:24:38
 Re: Cam Question for Drew and WTW. in reply to Drew, 02-12-2007 10:38:04
Thanks Drew,
I'd enjoy hearing what the latest combination produces....I assume that would be after this upcoming pulling season ;>)
Thanks again,
Doug
Zeke Miller
02-12-2007 04:57:50
Thanks for the input.
