super m pistons
joecup
02-09-2007 08:08:13
I have a super M with 4.125 pistons that have a 3/16 high semi circle dome with a 450 gas head running 150 psi compression. I would like somehigher domes for more compression. has anyone used dennys pistons or vo11brachts out of neb. please no dennys bashing just looking for
some leeds thanks in advance
mpiston
02-10-2007 08:18:11
 Re: super m pistons in reply to joecup, 02-09-2007 08:08:13
volbrachts are great people. Old M&W rep.
Their pistons are a very nice piece.
PullerBoy19
02-09-2007 17:13:07
Yea don't go to denny's the kits are not the right hp. Call lemmons or marlatt they are both out of rushvill. They are not cheap but they tuff motors.
yorkie
02-09-2007 16:27:30
pistons, don,t mess with denny,s carb shop he will skin you big time
you called it
02-09-2007 11:57:02
you mention Denny, he will rob you, your thought!
b barenie
02-11-2007 15:37:51
 Re: super m pistons in reply to you called it, 02-09-2007 11:57:02
yOU CAN CALL DENNY'S AND ASK (HOW MANY CC'S) ARE IN THE DOME ! FROM THERE YOU CAN CALCULATE COMPRESSION RATIO. If your running 150psi, with a 450 head and no stroke, your already at the top end of achiveable compression. if your running out of snot, then it's time to bore and stroke !
Vobracht, can answer the same question !
Arias can create what ever you want with a clay mold of the combustion chamber ! (bondo)
