dekalb super pull
farmallpullr
02-08-2007 20:13:58
how much does it cost to get in to watch the dekalb super pull?
mopowerpuller
02-09-2007 07:16:59
 Re: dekalb super pull in reply to farmallpullr, 02-08-2007 20:13:58
So I hear we can run topcuts at the SUPER PULL is that true for DIV II?
PullerBoy19
02-09-2007 07:28:18
 Re: dekalb super pull in reply to mopowerpuller, 02-09-2007 07:16:59
Yea I gess you can. It wont be fair to the guy with uncut tires but hey that is not my problem. I will have full cut's on my tractor if they something about it i will just run DIV III.
Div.II puller
02-09-2007 10:56:06
 Re: dekalb super pull in reply to PullerBoy19, 02-09-2007 07:28:18
Wow, you say you have this monster motor and you want to pull div.II. My guess your motor wouldn't be legal at a NATPA pull, but then its about winning a trophy, not fair competition.
PullerBoy19
02-09-2007 11:05:51
 Re: dekalb super pull in reply to Div.II puller, 02-09-2007 10:56:06
The NATPA div III rules say i can run a D17 block. Div III of COATPA even say i can run the D17 block. If you don't belive me check the NATPA rules it is rule number 10 of the NATPA.
Well then
02-10-2007 19:59:46
 Re: dekalb super pull in reply to PullerBoy19, 02-09-2007 11:05:51
NATPA top cuts legal in div 3 not div. 2. You said you were going to try and run div. 2 unless they said no then you were giong to run div. 3. D-17 is not legal in div. 2 in NATPA. mr monster motor.
PullerBoy19
02-10-2007 21:25:51
 Re: dekalb super pull in reply to Well then, 02-10-2007 19:59:46
I don't see why it can't be legal. Yes i know cut tires are only aloud in div 3 and not div 2. So why does COATPA allow top cut tires in div 2 when they no it is not allowd??
Firefarm
02-12-2007 09:41:18
 Re: dekalb super pull in reply to PullerBoy19, 02-10-2007 21:25:51
COATPA is NOT NATPA!!! They are not affilated in any way...
mopowerpuller
02-12-2007 14:29:45
 Re: dekalb super pull in reply to Firefarm, 02-12-2007 09:41:18
Firefarm could you give an answer to my question about topcut tires?Thanks MM
firefarm
02-12-2007 18:25:43
 Re: dekalb super pull in reply to mopowerpuller, 02-12-2007 14:29:45
The rules on the cut tire issue is in the rules at the bottom of the page. DO NOT touch the front edge of the bar...DO NOT change the angle of the bar...
www.coatpa.com
No cutting on leading edge
No changing angle on top of the Bar
{ If angle has been changed, pull in Div 3 }
PullerBoy19
02-12-2007 11:05:57
Yea I know. You want to know the other thing about them too groups. One group doesn't try and run off the little guys like COATPA in the antique Div because COATPA likes the fast stuff.
Shut Up Already!
02-11-2007 06:08:06
SHUT UP STUPID! It`s better to let everyone think you`re an idiot than to open your mouth and remove all doubt like you have. Go to Eaton, get cheated, get thrown out of Div II, cry about it then go home. But please SHUT YOUR WHINY LITTLE PIE HOLE MORON!
mopewerpuller
02-09-2007 10:04:14
Is that the WD in 5500lb Div III?, good luck .Now how about a real answer from someone in the know.
superh
02-09-2007 08:57:19
so I take it all the whining you did about the Dekalb pull that you are still going. Must be there is going to be less competition at the Dekalb pull.
SMP
02-09-2007 07:59:51
Ther is a big difference between FULL cut tires and TOP cut tires, I would suggest you find out what the difference is PullerBoy19.
PullerBoy19
02-09-2007 10:20:02
 Re: dekalb super pull in reply to SMP, 02-09-2007 07:59:51
I know the difference beween the two. Top cut is only the back hafe with out touching the front have of the bar. Full cut is when you cut on the bar. Still a Top Cut or a Full Cut it's still a cut in my book so lets just make Div II a any cut tire class.
URA PullerPuss19
02-11-2007 06:11:04
 Re: dekalb super pull in reply to PullerBoy19, 02-09-2007 10:20:02
See post above you stupid pullerpuss. It is intended for you pullerpuss19. Read it and do what it says and by all means SHUT THE FRUCK UP!
$10.00
02-09-2007 03:35:50
