Pulling Speedometer
Radar or GPS
02-07-2007 11:41:22
Anyone come up with an affordable speedometer to help keep that damn horn from blowing ????
IH H Puller
02-08-2007 06:57:58
 Re: Pulling Speedometer in reply to Radar or GPS, 02-07-2007 11:41:22
A guy that pulls with us uses a bicycle tire with a speedometer. You can see him in pictures from NATPA. It's a Massey 101.
speedo
02-07-2007 20:19:25
GPS calculates velocity based on change in position. Since it's only accurate to within about 10 feet, and you are only moving at 3-8 MPH, (4.4-11.7 ft/sec) - I don't know the sampling rate, but if it sampled every second, you could be off by quite a bit. You do the math... Not real accurate.
Maybe you could try picking a gear that's close to the speed limit and not sandbagging.
Charles McNelly III
02-07-2007 17:43:05
What about taking a speedo from a bicycle. Get it to run on the rim using a small wheel. Run your tractor to desired speed and mark the point on the dial. Might take a few trials, but it"s cheap. Charles
ChadS
02-07-2007 16:50:09
if they use an agritronix speedo,, get you a remote display module,, pick up the frequency and you have LIVE data to look at right off the sled.
Gettin' tuffer to see
02-07-2007 15:58:35
Does the GPS (like the Magellan 200 or others) have a big enough display to see while pulling?
JD hauler
02-07-2007 15:11:58
My magellan 200 works inside my house.
champspa
02-07-2007 14:07:57
didn't think gps was reading fast enough
John (MO)
02-07-2007 13:42:57
GPS
SMP
02-07-2007 15:08:07
 Re: Pulling Speedometer in reply to John (MO), 02-07-2007 13:42:57
GPS doesn't work indoors.
Dieselbear
02-07-2007 16:05:01
 Re: Pulling Speedometer in reply to SMP, 02-07-2007 15:08:07
That doesn't make sence. The GPS on the sled works indoors, why wouldn't a hand held one ?
Ol Gray A
02-07-2007 16:21:13
 Re: Pulling Speedometer in reply to Dieselbear, 02-07-2007 16:05:01
It's not a GPS unit on the sled. It is a high speed electronic counter
