9 bolt adapters
Island A
02-05-2007 09:47:57
I know this is a subject that gets hashed around a couple times a month but I did do a search and can't find the answer to my question. What is everybody using? Are they just flat plates with holes drilled in them, or are they machined with a "lip" of sorts onto which the 9 hole wheel fits?
In other words I have a JD A with cast hubs and 12 spline axles. Finding 9 bolt hubs for 12 spline axles is not easy. Can I make an adapter out of flat plate with holes drilled in, or do I need to machine a plate with a lip for the cast hub to fit into, and another lip for the 9 hole center to fit onto? I guess I am concerned about relying on 6 bolts on one side and 9 bolts on the other side to hold the wheels on with all the weight and torque of pulling a weighted sled. Opinions?
Dave
joyride
02-06-2007 17:19:16
 Re: 9 bolt adapters in reply to Island A, 02-05-2007 09:47:57
i know a man that makes the adapter that you are talking about, his name is baker. his e-mail address is [email protected]
Larry Baker
02-06-2007 17:11:46
we make a plate that you can use your hub and bolt to the adaptor and switch back to stock rims in a snap if you want to do that or go to a bigger size,you just slid out
no welding
we have them on both our '36 A's and keep them in stock for styled A's and g's also
fee
free to email
mjjk
02-05-2007 16:52:20
Dave, I have a set in the shed ready to go for your tractor, all I did was take 1" steel, cut in circle and drilled holes for six and nine bolt patterns, have had a set on my A for 10 years or so and did not have a problem yet with them. E-mail me if you have more questions.
FarmerSid
02-06-2007 09:30:19
 Re: 9 bolt adapters in reply to mjjk, 02-05-2007 16:52:20
Hey mjjk,
Would you mind passing on the info to make those 9 bolt adaptors. I mean the pattern and such.
Cheers! Sid
Cody Adgent
02-05-2007 18:34:09
Give Dave Brugger a call,He makes weld on hubs and adapter plates, nice guy, nice products. 608-762-5517
