m head
want to know?
02-03-2007 19:33:01
will a head off a straigh M fit on the super M block???? what are the head no,s?? thanks
MJF
02-05-2007 16:55:30
 Re: m head in reply to want to know?, 02-03-2007 19:33:01
The only problem you would run into is the pistons hitting the head you could just make clearance in the head.
ChadS
02-04-2007 10:06:20
If the SM has firecraters, you may run into problems. But if it has flat tops, or stepped head pistons, youll probably be OK. Look for 8574, 8060 heads, those are the two best gas heads for the M. Chad
jms1066
02-04-2007 19:21:56
 Re: m head in reply to ChadS, 02-04-2007 10:06:20
what is the number if it does have firecraters
