H Drivesaft support
daniel gillespi
02-03-2007 13:20:09
Hi in the pulling H's what do yall do with the driveshaft support theat goes above he hyd pump. Myine is cast aluminum or something and does not look relaly strong. Should I replace it with something cusom built with a b
aering in it?
K-Mo
02-03-2007 14:50:24
 Re: H Drivesaft support in reply to daniel gillespie, 02-03-2007 13:20:09
Are you talking about the clutch throwout bearing support?
The drive shaft doesn't have any intermediate support. The rear is attached to the flex coupler and the front is supported by the pilot bearing in the flywheel.
I don't know of any reason to beef it up. But, I'm not a puller so I could be wrong.
K-Mo
