Does a power block on a john deere b work out good
antiquehorsepower
01-31-2007 21:00:07
I"m thinking about having a power block put on a john deere b. And i would like to known if anyone has one on a john deere b and if they like how in runs ands pulls. Anyones ideas would be really helpful
jd b puller
02-02-2007 14:03:42
 Re: Does a power block on a john deere b work out in reply to antiquehorsepower, 01-31-2007 21:00:07
You've got mail...
WTW
02-01-2007 07:04:27
With out any doubt it is the easiest way to gain some cubic inch and compression. If you want the most bang for the buck stroke the crankshaft behind the Power-block. We run Power-blocks stroker cranks and Heisler heads on B's and the combination tuned accordingly seems to work pretty good for us. The hardest part other than the physical labor, is finding the Power-block and Heisler head to work with. A Power-block is a very good start and plenty if you are going to use it in a later B with a creeper gear, but if you are running pace classes and are competing against other tractors that can maintain pace limit you will also need a tractor capable of pulling the sled at the same pace to be consistently competitive which brings the need for the stroker crank and other alterations. Not to rain on your parade just some facts not fiction as I have been pulling B's in 3.5 and 4.0 mph for over 20 years. DW
antiquehorsepower
02-01-2007 08:34:16
 Re: Does a power block on a john deere b work out in reply to WTW, 02-01-2007 07:04:27
Do you know where i can find a good heisler head for a late john deere b. If so let me know i would be interested. Thank You for your advice
dboll
02-01-2007 06:10:37
definitely a power increase over stock, well worth doing in my opinion
antiquehorsepower
02-01-2007 08:36:09
 Re: Does a power block on a john deere b work out in reply to dboll, 02-01-2007 06:10:37
Thank You for your advice. Anymore advice just let me know. Thank You!!
