cut 15.5-38's
PullerBoy19
01-31-2007 08:56:26
I am looking for a set of cut tire. I don't care how they are cut. They can be V-cut,top cut i don't care.
WTW
01-31-2007 10:54:39
 Re: cut 15.5-38's in reply to PullerBoy19, 01-31-2007 08:56:26
I got a very nice set of Seberling brand 15.5 x 38" tires that are double cut (top and front of bar) They look like a 23 degree Firestone. Tires have been pulled about 5 or 6 times and are dismounted. Cases look like new inside and out and show no cracking. $500.00 Very nice tires for the money. Located in Eastern Iowa call me if interested. 319-389-6131. DW
PullerBoy19
01-31-2007 10:59:53
 Re: cut 15.5-38's in reply to WTW, 01-31-2007 10:54:39
Sounds like a very mean set of cuts. What kind of Hp do you need to spin them right now i have about 90hp.
WTW
01-31-2007 11:24:14
 Re: cut 15.5-38's in reply to PullerBoy19, 01-31-2007 10:59:53
The tires have a fairly aggressive cut and work real good for slower paced tractors. What little they have been run have been on unstyled B John Deere tractors in 3.5 and 4.0 MPH classes. There is plenty of bar for wear and room to re-sharpen in the future. If you plan on spinning these tires I will guarantee you that they will take a little power because of cut angles and aggression.
460/560
01-31-2007 10:38:49
I have a set of firestone f&r 15.5's. They are full cuts but need sharpened. One has a boot in the sidewall, otherwise they're real solid. On rims. Where are you located?
PullerBoy19
01-31-2007 10:52:12
 Re: cut 15.5-38's in reply to 460/560, 01-31-2007 10:38:49
I am located in Central Ohio. What kind of rims are they on. I will hopefully be in Princton Feb 24th. I will also be at the Dekalbe Supe Pull in Eaton,Ohio
460/560
01-31-2007 11:05:38
 Re: cut 15.5-38's in reply to PullerBoy19, 01-31-2007 10:52:12
They are on 9 bolt pressed steel rims. the centers have been moved in on them. I'm located about 45 minutes from princeton near terre haute. Asking about $350 obo.
PullerBoy19
01-31-2007 11:11:36
 Re: cut 15.5-38's in reply to 460/560, 01-31-2007 11:05:38
Will you be there feb 24th? I will keep you in mind about them tires
460/560
02-01-2007 10:37:38
 Re: cut 15.5-38's in reply to PullerBoy19, 01-31-2007 11:11:36
I don't know if I'll be at Princeton or not. Get back with me if you're still intrested
Charlie Kirschner
02-02-2007 09:33:50
 Re: cut 15.5-38's in reply to 460/560, 02-01-2007 10:37:38
Did you check on the tires you saw behind tire shop? I would be interested in the 14.9s If your not going to follow up on them I would give you a finders fee to tell me where there at if they are for sale.
460/560
02-02-2007 09:54:01
 Re: cut 15.5-38's in reply to Charlie Kirschner, 02-02-2007 09:33:50
I'll try to find out if they are for sell this weekend. I'll get back with you if i find anything out.
