kill switch wiring
leland b
01-30-2007 18:36:27
I just got a trailer emergency break away box.Do you run one wire to the negative side of the coil and the other to a ground ? To short the coil out and kill the engine ?
Thanks
Ian Johnsen
02-02-2007 22:49:44
 Re: kill switch wiring in reply to leland b, 01-30-2007 18:36:27
The jet ski kill switch is the way to go. A trailer brake away switch completes a circuit when the plug is pulled to allow a battery to engage the trailer brakes. You could use one to create a ground to your coil when it's pulled, but then you could short out or fry something. Jet ski kill switches have two sets of electrical posts to choose from. One set completes a circuit(like the trailer switch) and the other disconnects the circuit. If you use the second option, you can hook it up in line to the positive side of your coil.
Lamont
02-01-2007 14:40:09
I used an emergency kill switch from a jet ski. Easy to wire in. No danger in frying the electronic ignition. About $12.00.
the preacher
01-30-2007 20:06:04
That would work, but leaving the ignition on for any amount of time could fry the coil if it's shorted out.
Jerry Cent. Mi.
01-31-2007 06:18:50
 Re: kill switch wiring in reply to the preacher, 01-30-2007 20:06:04
On my tractor I went to the side of the coil that the power from the switch comes into the coil. I cut that wire and run two wires(One from each of the cutoff wires) to the breakaway switch. I my case I used a plug and receptcle from a standard home 120 volt setup with a wire across the terminals of the plug. When the plug is pulled the power to the coil is opened. I used a round receptcle so that I could lightly wrap the connection with electrical tape to avoid accidental disconection.
dboll
01-31-2007 09:56:03
 Re: kill switch wiring in reply to Jerry Cent. Mi., 01-31-2007 06:18:50
ditto to Jerry's reply, it's simple, cheap and it works!
