jd g pistons 90 over
jmducks
01-26-2007 19:09:13
I have a 52 jd g on lp and want to bore it 90 over what comp do i want to be at with lp? I would like phone numbers on some high compression pistons. I would like to know how much to shave off block and head? The block is not a power block and the head is not a flat head. Whose the best and grinding cams? Am i better off putting a different manifold on g? Im sure it was a conversion kit when lp was installed. Does a 60 or 70 manifold fit on the head? Am i better off with double barrel carb?
