Propane ?MM guys or anybody.
WANTS INFORMATI
01-24-2007 10:51:38
How many hp and or cubic inch can you feed on vapor only?In my limited experiance they start and run alright on vapor during warmup.Also these little warehouse forktrucks have a little beerkeg like tank with only one hose.I have atractor with a rusty gas tank and carb.Was thinking maybe the afore mentioned tank, a propane carb and a simple hookup mihgt work upto a point.Would it be worth thje effort?Thanks.
Ian Johnsen
01-27-2007 18:45:01
 Re: Propane ?MM guys or anybody. in reply to WANTS INFORMATION, 01-24-2007 10:51:38
Propane systems use a liquid draw tank. The valves have a draw tube that goes to the bottom of the tank. The liquid then goes to a converter. The converter ties into the cooling system of the engine and uses the heat to vaporize the propane liquid. This creates a more consistent vapor and helps eliminate tank freezing from rapid vapor draw from a standard tank. You have a couple of choices for style of propane carb. There are vacuum and mechanical. Most run on a vacuum style which uses a diaphram that react to vacuum to allow more fuel. In a performance application, I prefer a mechanical type. They have a rod that connects the butterfly to a barrel valve for the propane delivery. This rod is adjustable in length and therefore you can manually adjust your air/fuel mixture. Vacuum carbs require you to pull them apart and use different rate springs behind the diaphram. Propane is less combustable than gas, so most propane engines run higher compression to compensate. I have been told that propane is equivalent to about 110 octane and therefore burns very clean and allows for more timing.
LW
01-24-2007 18:33:50
Those forklift tanks are liquid out.We use them on tractors all the time.There are also different flow valves for the tank available.
dboll
01-24-2007 13:47:46
for heavy loads I would think you would want to run on liquid, some guys said they worked lp tractors with vapor and liquid open
dboll
01-24-2007 13:49:52
 Re: Propane ?MM guys or anybody. in reply to dboll, 01-24-2007 13:47:46
forgot to add I have a good pair of ub propane heads for sale ,$250.00 for the pair
