MW crank for Super M
Hayne D. Matthe
04-28-2002 19:06:13
Looking for a M&W crank that gives you 1" stroke and can work with stock rods and pistons. If you have one let me know what you want for it.
randy hall
04-28-2002 20:41:13
 Re: MW crank for Super M in reply to Hayne D. Matthews, 04-28-2002 19:06:13
the m & w hi-torque crankshaft gives an additional half inch stroke, not one inch. good luck finding one. you can have your crank stroked cheaper.
Hayne D. Matthews
04-29-2002 03:54:05
 Re: Re: MW for Super M in reply to randy hall, 04-28-2002 20:41:13
Thanks for the info, how much stroke can you go with the stock rods? I am not sure what pistons I have but I ran a compression check and it read from 160-165 psi. This is with a gas head. The tractor was on LP, now it runs on gas. I have been told that it most likely has some aftermarket pistons to have that much compression.
randy hall
04-29-2002 10:07:21
 Re: Re: Re: MW for Super M in reply to Hayne D. Matthews, 04-29-2002 03:54:05
you can go to 6.5 using your stock rods but you will have to do a lot of clearance grinding.
