SM Farmall 4 1/4 inch pistons
jhb
01-23-2007 05:01:46
Is it better to use the 3 ring 427 chevy piston or the 4 ring 427 chevy truck piston in a SM block without boring?
jhb
01-24-2007 11:38:46
 Re: SM Farmall 4 1/4 inch pistons in reply to jhb, 01-23-2007 05:01:46
Thanks to everyone. I appreciate your positive comments very much. This forum allowed me to previously put together a Farmall H very reasonable. Thanks again.
Reply
01-23-2007 06:26:29
The bare block will still need to be bored for an asceptable finish. The longer the skirt of the piston, the better.
jhb
01-23-2007 11:34:10
 Re: SM Farmall 4 1/4 inch pistons in reply to Reply, 01-23-2007 06:26:29
Won't a cylinder hone work ok rather than boring?
Reply
01-23-2007 14:39:39
 Re: SM Farmall 4 1/4 inch pistons in reply to jhb, 01-23-2007 11:34:10
If you can do this in such a manner, to come up with hatch marks at a 30 degree angle, for a good ring seal okay. Most important, a good machine shop can install rings where the sleeve was pulled, and bore at the same time. By doing this, not only will you have an excellent finished bore, but also a very good head gasket to bore seal !
jhb
01-23-2007 20:20:54
 Re: SM Farmall 4 1/4 inch pistons in reply to Reply, 01-23-2007 14:39:39
Thanks I understand but I can do it myself with
block in tractor.
RichH
01-24-2007 05:26:41
 Re: SM Farmall 4 1/4 inch pistons in reply to jhb, 01-23-2007 20:20:54
It would be time well spent taking the block out of the tractor to hone, if not just for final clean up when you are done honing. With my block bolted to an engine stand and tipped to a nice working angle it took a good hour per hole of honing and checking before the ripples in the bore started to hone out. When the ripples are gone that is about where you want to stop, at least that is where I had the right fit in my block. Then you have clean the bores really good to get "all" the fines out and in doing that you will drip on anything below, like the crank, and that plus the bearings should be taken apart to clean them up too. Cleaned good means a clean white towel is still clean after wiping down the bore two or three times. And yes you will need rings made to fill in the sleave groove at the top to help the head gasket seal and to help fill in space so you don't lose comprestion.
Good luck and have fun. RichH
PullerBoy19
01-24-2007 10:50:53
 Re: SM Farmall 4 1/4 inch pistons in reply to RichH, 01-24-2007 05:26:41
Rich I have a couple phone numbers of people that build pulling tractors that might be some help to you. They are not cheap but they have good strong runing tractors. They are from Rushvill, IN. So if you would like i will send you them there numbers.
