tire cutting in the Midwest
kodg
01-23-2007 03:49:05
I am looking for the closest place to get some tires cut for pulling? I am located approx. 110 miles E of St. Louis.
ben brown
01-24-2007 15:16:14
 Re: tire cutting in the Midwest in reply to kodg, 01-23-2007 03:49:05
they should work ok on the wd. sharping dont take as much time to cut as a new cut. most of the work is setting the tire up in machine to do the job. re cut a set of 32 inch 2000 puller the other day was like making a complet new cut was more touble then being the first cut trying to match the orignal cut. you can call me at 270-797-8964.
opinion
01-24-2007 05:32:25
Ira Banter 260-375-2535 quick turn around N E Indiana. Wilson is to slow and doesn't really care.
sos puller
01-24-2007 02:52:33
brian wilson 765-886-5022 greens fork indiana just off interstate 70.
JPatton
01-23-2007 19:14:23
kodg - Give Mike Aylward a call. He has cut several sets for me and I am very happy with his work. He is in Arbela, Mo. His number is 660-945-3819. Better call soon. He is a busy man.
Hope this helps.
J
ben brown
01-23-2007 10:38:22
i cut tires for pulling. machine cut to you spects. located in western ky dawson springs. south of the westen ky parkway. probley 150 or so mile from you my e-mail is open.
PullerBoy19
01-24-2007 10:37:57
 Re: tire cutting in the Midwest in reply to ben brown, 01-23-2007 10:38:22
Ben I have a set of tires already cut. How much trouble will it be just for me to sharpen them back up. They are 18.4x38 on 9 bolt rims should the fit ok on a 1950 WD pulling tractor ok??
