SM HD clutch
markloff
01-22-2007 23:06:58
Hello,
I didn't get much response on the Farmall board on this question so I figured I'd come to the real experts. What is a good heavy duty clutch set-up to put in a Super M? I'm looking to handle about 70-80 HP. I'm transplanting a 2-71 Detroit Diesel into it and want to upgrade as the tractor is now split and I'm in the process of gathering and machining parts. I have what I believe is a Rockford clutch on it now (12 springs on the pressure plate). Would that be good enough with a rebuild and a new clutch disk? Can you put different or heavy duty springs in that particular pressure plate or would it just be more cost effective to get an aftermarket one? What the best route to take here?
Thanks,
Mark
jhb
01-25-2007 06:20:53
 Re: SM HD clutch in reply to markloff, 01-22-2007 23:06:58
Unless you are planning to rev to 2000 rpm and pop the clutch you are over designing. Most pullers start out about 25% throttle, engage the clutch and then give full throttle. 70 or 80 hp is not that much really.
Gary Baker
01-23-2007 06:35:20
Go to your local tractor dealer and have them get a clutch from Ag Products. 4 or 6 button and get the pressure plate for a 986 IH. You will NOT slip this. Hope this helps
