1370 case puller
IRISHREDM
01-22-2007 12:28:28
would this be a good project has any one built one before if so what kind of hp is possible thanks
klglh
01-23-2007 11:50:25
 Re: 1370 case puller in reply to IRISHREDM, 01-22-2007 12:28:28
300 to 350 on Hp with stock components. 2670 pump 1570 injectors and either motor is the same but you will blow head gaskets some times.
IRIHREDM
01-23-2007 05:44:48
Not a lot of rules yet but we need to stay stock appering do these engines have many prolbems thanks
dboll
01-23-2007 05:05:25
forgot to ask if you have a 466inch limit
dboll
01-22-2007 16:19:33
1370 has a heavy rear end,you could put a 504 in a 1070 8spd., 1570 or 90 series heads (with thread in injectors) are a plus, I think the 1570 ect. has 11mm plungers and a 1370 is 10mm, don't quote me!
comfortking
01-22-2007 16:18:46
Yes! Bigger question is "What kind of dollars are possible"? It all comes down to Cubic Dollars.
