PERCENTAGE PULL FORMULA
MIKE LOKAI
01-21-2007 17:16:38
1.HOW IS PERCENTAGE PULL RESULTS CALCULATED
2.DISADVANTAGE OF THIS SYSTEM FOR COMPETITION
3.POST MESSAGE OR E-MAIL
THANKS IN ADVANCE MDLOKAI, OCALA FLORIDA
770 Puller
01-22-2007 00:11:48
 Re: PERCENTAGE PULL FORMULA in reply to MIKE LOKAI, 01-21-2007 17:16:38
BM350 you pull at Waterford any or Perry COunty fair?
bm3501466
01-22-2007 02:37:44
 Re: PERCENTAGE PULL FORMULA in reply to 770 Puller, 01-22-2007 00:11:48
adams and brown county, do you know where hillsboro is?
770 Puller
01-23-2007 00:23:08
 Re: PERCENTAGE PULL FORMULA in reply to bm3501466, 01-22-2007 02:37:44
Oh yeah, I'm from THornville, pull alot Perry,Morgan,Muskingum, and Washington Counties.
770 Puller
01-23-2007 00:22:57
bm3501466
01-21-2007 20:11:47
We do a lot of that around here. It is actually more popular here in Southern OH than transfer sled. The only disadvantage is a bad draw. When we pull on each weight the tractor that is last in line to pull is usually at a disadvantage because the track is worked up by the previous tractors. Also they normally take a long time since (the way we do it) every tractor has to pull the weight and then we add more. In lighter classes we usually go in 500 LBS increments while for heavier classes 1000.
A.P.
01-21-2007 19:04:26
The weight of the stone boat/sled divided by the weight of the tractor times 100. So a sled the weighs 8000# pulled by a tractor that weighs 5000# would result in a percentage of 160%. At least thet is the normal formula used for stone boat or dead weight pulling.
