U Moline weight
U Puller
01-20-2007 20:22:15
Is 4500 possible if so how much trouble is it to get there.
light u
01-22-2007 05:25:35
 Re: U Moline weight in reply to U Puller, 01-20-2007 20:22:15
mine weight 4050
U Puller
01-21-2007 19:26:50
Thanks for the info guys.
family tradition
01-21-2007 10:25:05
My uts weighs about 4300 empty. custom wide front w/ rack and pinion steering, aluminum radiator, weld on hubs, custom disc brakes, and a LOT of little nic nac stuff too numerous to list. I have heard of some lighter.
Mopower
01-21-2007 08:53:20
Depends on the year, but my 1947 UTU weighed about 5200 with cast centers. Put 9-bolt hubs and sheet metal wheels and you will be able to pull 5000#. Use a light radiator, aluminum or fiberglass tranny cover and oil pan, and swap for UTS or G axle housings and you ought to be there. The UB is a bit heavier. The UB I pull was simply swapped to sheet metal wheels and weighs 5030#. I hope to get my UTU down to 4500# maybe next year. Good luck.
