M piston size question
CPR
01-18-2007 18:09:17
I know of dry block Ms with 5.25 pistons, but what are some of the big inch Div. 3 guys running? How big can I go without having to go waterless?
Thanks,
CPR
superih
01-19-2007 05:09:27
 Re: M piston size question in reply to CPR, 01-18-2007 18:09:17
Most Div 3 M's are running 4-3/8 to 4-1/2 some bigger, most running water in at least the top of the block staying under 500 cubes. There are 4-7/8 and maybe 5 inch motors that are still running water. There is a Baker motor that is 5-1/4 x 8 inch, that is the biggest M going right now.
Charles McNelly III
01-18-2007 19:38:55
I think someone needs to look at the ruler again. 5.250? I have heard that 4.500 is pushing it.
charles
SMP
01-18-2007 19:49:00
 Re: M piston size question in reply to Charles McNelly III, 01-18-2007 19:38:55
There is a Baker built M running 5.25 pistons 8 in. crank 693 cu.
Charles McNelly III
01-19-2007 16:22:41
 Re: M piston size question in reply to SMP, 01-18-2007 19:49:00
I wonder what kind of HP and torque numbers that engine puts out. I bet it sounds good running down the track. I bet you could buy a new truck with the price of that motor alone. :)
Charles
CPR
01-19-2007 18:18:01
 Re: M piston size question in reply to Charles McNelly III, 01-19-2007 16:22:41
That 693 does sound good. Another of Mr. Baker's customers mentioned the number 450 for horsepower. It is completely waterless. Good for power, but not convenient for moving around a pull, needs a tow...
OK, if I'm "safe" at 4.5" pistons, will I need to install them in a C-264 or C-281 block, not the M block?
Also, if guys are running 4.5" pistons and staying under 500cid, why are they not also running an 8" crank (509cid)?
Thanks for all of your help. It's getting me pointed in the directions I want to go.
CPR
Charles McNelly III
01-20-2007 16:49:05
 Re: M piston size question in reply to CPR, 01-19-2007 18:18:01
Try emailing www.Murphysmotorservice.com
They can answer anything about what you want to do. He had said they were going to build some "kits" for the Farmall M. Good luck
Charles
