Question for Chad
Trkr
01-18-2007 12:17:17
On your limited slip diffs you say on other brands you run a shaft between the brakes,how do you do that on a Super M?Do you have to remove the spyder gears?Thanks
ChadS
01-18-2007 13:51:15
 Re: Question for Chad in reply to Trkr, 01-18-2007 12:17:17
On the Supers, you can just pull off the brakes, the bearing cage, and pull the pinion shafts right out, without taking anymore apart. Straight H-M"s you have to tear the final drive apart, due to the brake pinion shaft bearing cages not passing by the bull gears. The kit installs right back uopn reassembly. Chad
ChadS
01-18-2007 13:52:22
 Re: Question for Chad in reply to ChadS, 01-18-2007 13:51:15
So,, no, you dont have to pull the differential, or the spiders even out of the tractor. Chad
Mopar-Harris
01-19-2007 09:02:28
 Re: Question for Chad in reply to ChadS, 01-18-2007 13:52:22
How about on a 101 Super M-H? Cost?
ChadS
01-19-2007 10:18:47
 Re: Question for Chad in reply to Mopar-Harris, 01-19-2007 09:02:28
Yep. have done many 101's, 44's, 444's. They are very simular to the olivers,,, Would need the whole differential, from brake drum to brake drum. It all hides behind the brake cover plate. Chad
Just did 44
01-22-2007 05:16:24
 Re: Question for Chad in reply to ChadS, 01-19-2007 10:18:47
I can tell you that unless you have disc brakes or band brakes, it will be a chore. I had shoe brakes and went to band brakes from a 1948 MH 44 and was able to make it work. No room for the shoe brake backing plates. You could however keep the shoe brakes on one side.
Trkr
01-18-2007 14:13:47
I'm interested in getting one,I'm still dont understand how you connect the brake pinions together?Is it hollow through the differential where the brake pinions go?I thought there were spyder gears in there.Thanks again.
ChadS
01-18-2007 14:21:31
 Re: Question for Chad in reply to Trkr, 01-18-2007 14:13:47
The differential itself is hollow, the pinion shafts are not, so we have to bore them to put the "axle" thru the pinion shafts. We would need both pinion shafts, and one brake cover. It just slides in when you put the pinion shafts back in the tractor, put the brakes back on, adjust the clutch tension and your done. 574-893-7437 Chad
