hich and tires
Ronald Hills
01-16-2007 13:50:34
how much difference in hight of my hich if i change tires from a 38" to a 36"
Ken B.
01-17-2007 17:11:10
 Re: hich and tires in reply to Ronald Hills, 01-16-2007 13:50:34
There is no way of telling . It should be around 2" If the tires are worn about the same. But this all depends on to many things to answer.
Ronald Hills
01-18-2007 05:05:30
 Re: hich and tires in reply to Ken B. , 01-17-2007 17:11:10
thank alot for your help
Ken B.
01-16-2007 16:33:25
Are you keeping the same size tire ? As in 18/4 38 to 18/4 36
Ronald Hills
01-16-2007 18:06:08
 Re: hich and tires in reply to Ken B. , 01-16-2007 16:33:25
no no no im changing from a13.6/38 to a 13.6/36 what will happen to my hich. will it drop a couple of inches??? what should i do??? write back
mohead10
01-17-2007 15:50:44
 Re: hich and tires in reply to Ronald Hills, 01-16-2007 18:06:08
If you are A puller, with A pulling tractor, you should have A pulling hitch, that is adjustable .So if you lose an inch or two adjust it back up.
Ronald Hills
01-17-2007 16:52:16
 Re: hich and tires in reply to mohead10, 01-17-2007 15:50:44
i built it up so it is just the right hich it is not ajustable but thanks i wll put in a peace of steel to make up the difference
