Why?
LL
04-22-2001 12:57:49
Why do some people insist that cheating isn't really cheating as long as nobody can prove it? I like to pull farm stock but not against 70 HP M Farmalls or A JDs. Am I just whining or is this a legitamate problem at most pulls?
SODDBUSTER
04-26-2001 17:25:28
 Re: Why? in reply to LL, 04-22-2001 12:57:49
THE DYNO IS EASY FOR ME TO GET PAST.SPEED LIMIT IS THE ONLY WAY.THEN EVERYONE IS ON THE SAME PLAYING FEILD.MAKES IT MORE INTERESTING.
Greg H.
04-23-2001 13:13:34
First off you have to have a pulling club that has rules, before you can define cheating. I doubt you'll find many pullers who in all honestly pull stock, so just get used to it, and make the best of the equiptment you have to work with and take your spankings with a smile on your face just like the rest of us poor boys. If you don't like getting beat than cheat, otherwise have fun, and enjoy your evenings out with the fella's and your family all at once. That's what I've done. Greg H.
DYNO
04-23-2001 10:24:06
AFTER EACH PULL A TRACTOR GOES TO A CHECK AREA WHERE THE TOP PLACES WILL BE DYNOED. THE PULLER GETS OFF THE TRACTOR AND TOUCHES NOTHING, IF HE DOES HE IS DISQUALIFIED. SOUNDS LIKE FUN DOESN'T IT.
KB
04-23-2001 07:41:52
Speed limits solve a lot of problems.
ll
04-22-2001 15:13:14
The question should be which came first pulling or cheating?
Tom H
04-22-2001 13:36:37
Some people have to cheat to win. I think it's just fun to get together and have fun.Seems people have to push the rules so they can try to win. In my club we just pull for points and at the end of the year the one with the most points gets a trophy. Still they find ways to cheat,guess thats why we have a rules commitee.
Tom H
Bob
04-23-2001 08:39:33
 Re: Re: Why? in reply to Tom H, 04-22-2001 13:36:37
Hi Tom: Yes commitees help say which members will win, and they may favor their buddies! My 2 cents. Bob
cc
04-24-2001 17:45:10
 Re: Re: Re: Why? in reply to Bob, 04-23-2001 08:39:33
Dyno's don't work they are easily beaten, speed limit is the sure catch all.
KB
04-26-2001 07:13:29
 Re: Re: Re: Re: Why? in reply to cc, 04-24-2001 17:45:10
Abosolutely correct. If you want to keep it fair....have a speed limit. After you have enough power to set off the horn it really doesn't matter how much more you have. Then have open classes too, so if you want to spend alot and go fast.. go for it.
jakee
04-27-2001 22:36:24
 Re: Re: Re: Re: Re: Why? in reply to KB, 04-26-2001 07:13:29
no to make thing,s fair you must have tear down rules and en-force them, just like they do in any other motor sport.then wen your caught cheating you go home.514 cubic inch M,s for trophys?800 inch molines, 300 inch H,s and only god noes what the deere herd has?the only way to move the sport ahead is clean it up---we are the only ones that can,t interest sponsers , because it needs to be run more profesinally.
oldtimer
05-12-2001 20:08:40
 Re: Re: Re: Re: Re: Re: Why? in reply to jakee, 04-27-2001 22:36:24
we run 3 classes, stock, notso stock, open, stock must be stock appearing,run low gear, stock RPM,RPM check after scales and in line to pull,not so stock same rules,these are the guys that have someparts other than stock we all know each other and help build the tractors.open is open ,anything you can afford in that wt. class,we just have fun pulling.
