john deere G
jarrett findlay
01-14-2007 21:09:16
Hello to all. My brother and i are both building 51 G's both have been bored .120 and m&w h/c pistons both have flatheads and hotter ignitions and cold manifold. the questions are where do we go from here for more hp without stroking the crank? our thoughts we install cam's, new carbs, roller rockers and someone had told us of offset grinding an a rod to add some stroke any info on any of these things would be very helpfull thanks jarrett
jmducks
01-26-2007 18:54:58
 Re: john deere G pistons in reply to jarrett findlay, 01-14-2007 21:09:16
Hi i have a 52 g on lp and i am boring to 90 over and want to know what high comp. pistons to use. I would like to get 60 - 75 hp. I also want to know how much to shave off block and head safely. I also am considering custom cam. please green fans help
G Fever
01-15-2007 16:15:45
 Re: john deere G in reply to jarrett findlay, 01-14-2007 21:09:16
Jarrett,
Listen to jd b puller and jd lover. You need to call and talk to Keith Merfeld about what you want and he will tell you what your best options are! His # is 563-582-8710 He builds cranks rods piston ETC.....
G Fever
jd b puller
01-15-2007 16:05:22
Don't waste your money with an offset grind. You'll be within $500 vs. doing it right. Stroke it right to begin with. There's plenty of discussion threads on this.
jd lover
01-15-2007 14:20:10
stroke it and you will never be happier,night and day difference.
