MM U aluminum radiator
PGpower
01-10-2007 05:43:39
looking for a different radiator for my MM U. I know some of you have installed different radiators and maybe some aluminum radiators. What have you used and where did you get them. Any info would be helpful. Thanks. Lewis
PGpower
01-12-2007 07:58:35
 Re: Thanks for all the input. in reply to PGpower, 01-10-2007 05:43:39
Thanks for all the input that everyone provided.
family tradition
01-12-2007 09:14:21
 Re: Thanks for all the input. in reply to PGpower, 01-12-2007 07:58:35
I run an aluminum on my UTS. I found it on Ebay. I have done a couple on other tractors and used a radiator out of a mid 80"s dodge, chrysler, or plymouth minivan. You just have to make your on bracketry to hold it. We also use the factory electric fans on these radiators. We pick them up at the local salvage yards for 35-50 bucks for both parts, fairly cheap and a big weight loss.
PGpower
01-12-2007 12:28:25
 Re: Thanks for all the input. in reply to family tradition, 01-12-2007 09:14:21
Thanks. I have found some that will phisically fit, i just didn't know if they had enough cooling capacity or not. Guess it doesn't take much rad if a caravan rad will work. I plan on using a 12v fan and water pump, so I am assuming as long as i find a rad that fits, i will be ok for capacity.
