cam grind
jdjack
01-08-2007 19:47:21
Have a JD A that is bored .125 stock stroke and ports opened up alittle. Head shaved about .50. Want to get cam ground. What is a good grind for this setup. Will be running at the most 10% over stock rpm's. More duration and or more lift?
Jeff Asbury
01-16-2007 16:33:03
 Re: cam grind in reply to jdjack, 01-08-2007 19:47:21
Comments!!
BushPapa, I somewhat disagree about trying to get lots of valve lift. But I totally do agree with the best performance VJ that you can get or afford. Drew, You are correct about the valve lift thing, A flow bench will tell you so. I KNOW! Goldsburg, You are partially right about wanting "DWELL". But lift is not the proper way to get it. Cam PROFILE & HIGHER ROCKER RATIOS are the way to get what you want.
All, Go to www.murphysmotorservice.com Go to the rocker page, click/see how rockers perform at the top of the page. The "dwell" that Goldsburg mentions is more properly called AREA UNDER THE CURVE. That is what it is all about. As you can see by the graph, the rockers increase area under the curve considerably. But the valve leaves the seat on opening & touches the seat on closing the SAME time as a stock rocker. BUT the action in between is what is altered, THE AREA UNDER THE CURVE. You can have 6 cams with the same duration @.050 & the SAME LIFT, but totally different profiles. IF YOUR cam grinder says thats BS, then I would suggest finding another cam grinder!!!
Jeff Asbury
BushogPapa
01-10-2007 08:21:26
Best thing you can do is increase valve Lift, and get not the best valve job you can afford...but THE BEST Performance Valve Job available...more HP is available at the valve/Valve Seat area than you can imagine.. Custom grinding the valves, to re-shape them and polishing them..with only one single light cut for the seating surface... Multi-angle cuts above and below the seat, into the 1st 1/2" of the port..the Seat NOT Lowered, just the seating surface moved out on the valve.. This can give you an effective duration increase
as the valve starts "Breathing" Before .050"lift. .050" is the lift amount normally listed as where "Breathing" starts..SO..Duration increases with this kind of work.. Cheapest HP you can make..!! Match the Ports to the head and polish the combustion chambers... Clean out the Entire air Intake System....Yea, even the Wasp Nests in the intake stack..!! GOOD LUCK, and Have a Great Summer with it..!! Ron..
Drew
01-10-2007 10:57:43
 Re: cam grind in reply to BushogPapa, 01-10-2007 08:21:26
Miles of valve lift isnt the answer that some people think it is. Yes, it can help to an extent, but you also need more duration. Without putting it on a flowbench for an exact number, I would guess that head peaks out in flow somewhere in the .500-.600" area of valve lift. After this peak is reached, you could take the valve completely out of the head and it will not flow any more air. So it does not do any good to have .700 or .750 valve lift when the valve isnt the restriction.
Goldsburg
01-11-2007 06:04:12
 Re: cam grind in reply to Drew, 01-10-2007 10:57:43
Well, it is not exactly true to say there is not a benefit. If a cam and rocker system is pushing the valve beyond the threshold of increasing flow, it is still getting a longer "dwell" in that area of highest flow (given same duration on a cam). So a slight "over lift" can be beneficial...
Regards,
Goldsburg
MJF
01-09-2007 14:43:58
Check out his website he has a lot of good stuff there
Richard Reed
01-09-2007 08:13:28
Hello,
I pull a J/D "GM". Currently running custom aluminum .125 O/S pistons,flat head with big valves and springs, cold manifold, DLTX B/N 51,MSD box and electronic Ign.With this set up, how much improvement would I get with the roller rocker arms? Please send information on price and availibility. Thanks
buickanddeere
01-10-2007 16:08:05
 Re: cam grind in reply to Richard Reed, 01-09-2007 08:13:28
The larger valves just get shrouded more by the combustion chamber "eye brow". The air/fuel mixture can only flow from out from under one side of the valve. Measure and look from the water jacket side. Then cut as much eye brow down as you dare. And use an oversized valve seat cutter and cut the eyebrow back so the air/fuel can flow all the wya around the valve.
Jeff Asbury
01-09-2007 05:00:11
jdjack, I would suggest our high ratio roller rockers. They will do about the same as a cam regrind and are a whole lot easier to install. You can expect 3-5 HP, possibly more. We have them in stock.
Thanks Jeff
Ken 46
01-10-2007 10:23:44
 Re: cam grind in reply to Jeff Asbury, 01-09-2007 05:00:11
Do you have high lift rockers for the Oliver 88??
I would appreciate more info.
Thanks - Ken
Jeff Asbury
01-10-2007 10:55:22
 Re: cam grind in reply to Ken 46, 01-10-2007 10:23:44
Go to www.murphysmotorservice.com There you can see all the rockers we are currently offering.
Thanks Jeff
Richard Reed
01-09-2007 08:29:45
Please send me all the information you have on the roller rocker arms.
Thanks
Jeff Asbury
01-16-2007 16:04:06
 Re: cam grind in reply to Richard Reed, 01-09-2007 08:29:45
Richard, There is nothing to send as I do not have a catalog. All rockers that we are currently offering are pictured on the web site (www.murphysmotorservice.com), including pricing. We have rockers for your A in stock.
Thanks Jeff
