new NTPA class
slowride II
01-08-2007 18:23:43
have you guys heard of the new pro farm class in NTPA? i was tickled pink when i read about it in the puller i just got today. i think it great! now the local guys can git in and compete in the ntpa with the SS diesel and UNL. classes. tell me what ya think!
slowride>
AC
01-08-2007 21:07:38
 Re: new NTPA class in reply to slowride II, 01-08-2007 18:23:43
I think its great if you are an IH guru or a John Deere weenie. The 466 cube limit sucks! Must be no one wants a 504 Case or a 585 Moline to beat them. Just my opinion, and we all know I am an idiot! ;)
dboll
01-10-2007 11:53:56
 Re: new NTPA class in reply to AC, 01-08-2007 21:07:38
If Jason in Il thinks a Case or MM can't win an out of field he hasn't been to enough pulls. I have seen old 1370's wax much newer stuff and I have no doubt that I could make a 1570/2590 compete in field classes. They are good for at least 300hp out of the box with no pump or turbo mods.,now let's bolt on a 3lm466 and do flow and pump work and see what happens!! PS remember those nasty G1000's that used to pull?
Jason In IL
01-10-2007 12:57:16
 Re: new NTPA class in reply to dboll, 01-10-2007 11:53:56
You are correct on the G1000's, they did do well. But the ones that did the best were propane powered witn nitro in the tank. I know this for a fact because a fellow that used to live and pull in the county I live in ran a G1000 propane, with nitro in it. As for a Case, I go to and compete in pulls from central to northern IL and I have only seen a couple of them do any good, unless they are allowed to run high rpm's. I am talking 3000 or better. As for the sled guys, don't remember who, but two of them were at the Champaign IL pull this past summer, and one is from n-IL. And yes the 466's have beaten the big engines on numerous occaisons, running 26-28 mph.
Think About This
01-10-2007 09:53:36
Case and MM both made 451's .The 466 limit allows the Fords and AC's to compete.
The bigger you go on cubes the more the IH's and JD's will dominate.Also it gets alot more expensive.
Jason In IL
01-09-2007 10:22:03
You must not have seen any of these Pro-Farm tractors run. According to several sled operators I know, they say these are running at the same speed down the track as a lot of the Super-Farm tractors, but for a lot less money invested. As far as the statement about a Case being a strong unit, come on gimme a break. I go to pulls all summer long and I have yet to see a true Case that can compete. Heck they can even win in a regular "out of field " class. Food for thought; the ILLINI STATE PULLERS run a pro-farm class that allows up to 650 c.i., and guess what, not a Case or MM in the group. But there is a good running Massey.
Curious
01-10-2007 06:27:41
 Re: new NTPA class in reply to Jason In IL, 01-09-2007 10:22:03
Not at 466 CID. Name the several sled operators you refer too.
AC Is An Idiot!
01-09-2007 06:06:18
That class might be the stupidest set of rules ever written. NTPA did not want this class but WPI forced it on them. So they changed the rules from the original proposed rules to this joke. The changes were designed to kill the class. And these tractors will not compete with Super Farm, Pro Stock or Super Stock Diesels. According to the rules they are to compete in Pro Farm only. And only at the state and regional level. This class is the plantin` tractor class. But they`d plant corn faster that they will ever pull a sled. As much as I hate to agree with Ol buddy AC I have to on this rare occasion.
AC
01-09-2007 19:03:27
 Re: new NTPA class in reply to AC Is An Idiot!, 01-09-2007 06:06:18
Idiotic question..
Whats WPI ?
Scotmac
01-10-2007 08:40:16
 Re: new NTPA class in reply to AC, 01-09-2007 19:03:27
WPI stands for World Pulling Inc. It was created by NTPA amidst some pending lawsuits back in the early 80's. WPI is governed by a board of directors consisting of some of the old NTPA directors and employees. They pretty much dictate how NTPA operates. The NTPA board, I believe can be over ruled by WPI.
jdeere70
01-10-2007 08:55:41
 Re: new NTPA class in reply to Scotmac, 01-10-2007 08:40:16
Close but not quite. WPI is World Pulling International. It was formed as a financial controling board in the 80`s when NTPA was nearly $300,000 in debt. Basicaly WPI owns NTPA and calls all the shots.
Scotmac
01-10-2007 09:01:47
 Re: new NTPA class in reply to jdeere70 , 01-10-2007 08:55:41
I remember several guys out here threw some money at it....but wasn't there a lawsuit pending from a guy in in Minnesota that got injured when the sled malfunctioned?
jdeere70
01-11-2007 06:13:11
 Re: new NTPA class in reply to Scotmac, 01-10-2007 09:01:47
WPI was formed in the early eighties. The sled malfunction/law suit you refer to is probably the one that happened in 1998.
jdeere70
01-09-2007 08:27:12
Here are the rules copied from the NTPA website:
Pro Farm Class
Note: The Pro Farm class will run under NTPA Super Farm division rules, plus the following rules. This class be only sanctioned at State and Regional level
A. Engines
1. No engine larger than 466 cid. (+ or � 1 percent) Diesel fuel only 2. Engine head must be OEM agricultural-type (no aftermarket head) for that brand engine.
3. No overhead cams allowed. Maximum 2 valves per cylinder 4. Only Manifolds allowed must be OEM rubber tired agricultural type manifolds for both intake and exhaust. 5. Turbo restrictions: Turbo must have a 3 inch maximum ID pipe with a 3 inch minimum length before and after the turbo no more than 3 inches from the face of the wheel. All inlet and exhaust air must flow through this restriction,
6. The maximum allowed size pump for diesel injection is a p-pump. (No aftermarket housing). Only one plunger per cylinder allowed.
B. Competition Pro Farm tractors are only allowed to compete in the Pro Farm class.
C. Tires Maximum size of 20.8 x 38 non-radials with a maximum of 56 lugs allowed, Tire can be no larger than a maximum of 220 inch circumference when inflated to 20 psi. Tread width not exceed 21 inches when mounted on a 20 inch wide rim. Tires must be mounted on steel rims only. (No aluminum rims on rear)
D. Weight This class shall compete at 10,000 lbs.
E. Safety All OEM chassis (non-component) Pro Stock rules, including shielding, safety and SFI requirements, apply to this class.
