JD-1936 A
joyride
01-05-2007 15:25:57
hello,
am looking for a set of 9 bolt hubs to fit a 10 spline axel on a 36 A, any idea;s?
thank-you.
NOS88
01-06-2007 10:20:40
 Re: JD-1936 A in reply to joyride, 01-05-2007 15:25:57
I have a set of 15 spline axles and bull gears that will work. I had a 37 A that I was going to make a puller and couldn't find hubs. I new 15 splines were easy to find. I had them in the tractor before I sold it and put it back to stock. I would sell these axles resonable!
JOYRIDE
01-06-2007 11:13:06
 Re: JD-1936 A in reply to NOS88, 01-06-2007 10:20:40
thank-you,
but have found a set of hubs.
joyride
01-06-2007 08:37:55
THANK-YOU.
DSK
01-05-2007 19:48:18
There are a few sets of these around but they are quite uncommon and usually very expensive. I saw a set at a swapmeet several years and the guy wanted half a farm for them. A better alternative to shelling out big bucks would be to replace the axles with a pair of 15 spline axles out of a mid 40's A, they will interchange and the 15 spline 9 bolt hubs are far more common & reasonably priced. You should be able to find a pair for around $150. The 15 spline axles are plentiful as well.
