M WITH 560 DIESEL MOTOR
miracle child
01-02-2007 14:41:01
OK GUYS HERE WE GO NEW PROJECT WILL THE 560 DISEL MOTOR LINE UP WITH THE M TRANS AND WHAT KINDA TROUBLE WILL I RUN INTO
dboll
01-05-2007 12:57:30
 Re: M WITH 560 DIESEL MOTOR in reply to miracle child, 01-02-2007 14:41:01
To say a 282dsl. (560) is one of the better engines is an insult to IH. They blew head gaskets, puked the sleeves into the crankcase and suffered other ailments and are they are lightly built. I know some guys got good service from them but others had nothing but problems. The 361/407, 414/436/466 are a differen't story and have earned my utmost respect as excellent, durable engines. Go with something else besides the 282
willywonka2
01-04-2007 21:04:37
you will need the 560 flywheel and frame rails, pressure plate and disk from the M do to IPTO splines in the pressure plate of the 560. Im only guessing that the M clutch will work on the 560 flywheel.
MJF
01-05-2007 13:04:20
 Re: M WITH 560 DIESEL MOTOR in reply to willwonka, 01-05-2007 08:17:34
I kinda feel bad for Jerry, a guy with no life that makes fun of people for owning IH tractors. So jerry if IH is junk what is a better tractor? what tractors do you own?
anyways does anyone have a picture of an M/560 or an H/460 I'd love to see one
Mr. Jerry LaGod
01-03-2007 18:54:03
The tractor and the motor are both junk. Send them both to the scrap yard. That way you`ll get more than either one is worth.
really
01-03-2007 19:41:42
 Re: M WITH 560 DIESEL MOTOR in reply to Mr. Jerry LaGod, 01-03-2007 18:54:03
Jerry, we are all dying to hear what the ultimate tractor is. I don't think you've said anything of any value except that IH is junk. Please enlighten us.
JD4320abh
01-03-2007 19:00:25
The 560 diesel to some can be argued as one of the best engines ever made. There have been many Deere's in my family and they have been good, but I feel that IH motors like the 560 diesel and the 407 rank among the best of all colors. That is just my opinion. Don't let that Jerry guy get you down, from what I have seen from previous posts he is just merely a keyboard mechanic.
miracle child
01-03-2007 13:10:29
WHAT ABOUT THE REAR END WILL IT HOLD UP TO THE POWER
mshultz
01-03-2007 04:24:55
Unless you just have parts laying around looking for a home, go with something bigger. A 407 or 466 will bolt right in the same bellhousing Just need to make a flywheel, big clutch, get your throttle linkage worked out and extend things a little.
MJF
01-02-2007 16:31:35
You should be able to just bolt the 560 rails to the M, I know thats what they do when they put a 460 engine in an H
bm3501466
01-02-2007 15:57:15
It will line up with no problem. The frame rails though will need to be made longer since the motor is longer. Also your hood and steering shaft will have to be lengthened.
bm3501466 Is An Idiot!
01-03-2007 18:56:04
 Re: M WITH 560 DIESEL MOTOR in reply to bm3501466, 01-02-2007 15:57:15
U R A moron with an ID 10 T virus.
gfs
01-02-2007 18:38:42
Saw this done with a 706 gas, largest obstacle was the flywheel clutch, some adaptation required.
