MF 97/MM g 705
Kevin
01-02-2007 12:48:48
I have a MF 97, same thing as the g 705 i believe, and i was wondering what i can do with the 504 diesel for alittle more power. Ive done alittle fiddling with the pump wich is a roosa master, but i think im going to try and get a pto shaft on it and have it done on a dyno becuase i probly did more bad than good, i was getting a thick grayish smoke on a tuff pull. Overall the motor is pretty solid, with still staying safe how many rpm can i turn? The tractor has the old tach wich isnt working, is that fairly accurate if i get it working? Should i put an egt guage on it to be safe or is that only necasary for turbo diesels? Ive talked to some people bout crankin more rpm and they said to be carefull, are they talking EGT's or metal shrapnel? Last but not least what should one weight in at with power steering and dual remotes?
