attention chads (400 head needs bigger valves)
ollyeater
01-02-2007 06:25:42
do you know of anybody thats ever put bigger valves in a 400 head if so what kind , size etc
ollyeater
01-02-2007 10:27:26
 Re: attention chads (400 head needs bigger valves) in reply to ollyeater, 01-02-2007 06:25:42
iwas going to run a 6inch stroke but our club is limited to 4mph and 10percent over stock rpms
ChadS
01-02-2007 10:51:21
 Re: attention chads (400 head needs bigger valves) in reply to ollyeater, 01-02-2007 10:27:26
Ok. What I do on the 6 inch strokers with the 400-450 heads is give them a port/polish in the ports. New manifold is a must!! You are flowing more air for sure,,, but not to the point of needing bigger valves. If its under 220 psi cranking pressure, the stock valves will feed it as long as you port the head, Im not saying go all out on the porting,, just a nice clean up to smooth it out. With the port work, new manifold it will do the same as big valves, and then use the carbs' venturi size to match it all up. Ive done that quite a few times and they have amazing low end power. 400 head, ported, cleaned up
450 cam
Vinson manifolds are sold new bout anywhere,,
M carb throttle body, they work better in the long run.
6 cyl carb bowl,, they have a bigger metering stem, and has a larger idle circuit thru the bowl
Good fuel,,,,, Im a beliver in ethanol, so if you can get E85, they run great and make power with E85, mixed with 93 pump gas. How much to mix is relitive to compression pressure,,,, the higher the compression, the more ethanol you can burn. Electronic ign,,,, its just better,,,
lighter springs in the mechanical advance,, picks up throttle responce,,,
stiffer governor spring, speeds up governor responce time, and throttle responce, holds the carb open longer too under a load.
Thats the recipe for a real good engine for 6 inch stroke,,,,, My opinion is the big valves are not needed though,,, Hope this helps,,, More info if you need it! Chad
ChadS
01-02-2007 10:24:03
Let me ask you a few questions first,, Are you running really high rpms? does your engine have an obscene amount of compression? Does the engine have the stock crank in it? If the answer is no to all of the above, then you dont need them. You can port/polish the ports and the valve bowls, match port the manifold to the gasket, and do about the same thing that the big valves would do. If its low compression, big valves wont get you anywhere,,, JMHO,,,, Maybe look into a LP valve set,,, I think they are just a tad larger than stock,,,,, If you want, tell me a little more about the engine your running, post the info here, or email me if you dont want to post it,,,, [email protected] is the address. Chad
