farmall 460 weight
super_m
01-01-2007 09:50:12
my 460 weighs 4490 with driver with pressed steel all around.it has all the hydraulics,power steering and pto took out.is there anything else i can do to get it lighter,how light can i get it?
bm3501466
01-02-2007 13:36:13
 Re: farmall 460 weight in reply to super_m, 01-01-2007 09:50:12
Why were my posts deleted?
bm3501466 Is An Idiot!
01-03-2007 11:57:12
 Re: farmall 460 weight in reply to bm3501466, 01-02-2007 13:36:13
Because you are a moron.
bm3501466
01-03-2007 12:04:40
 Re: farmall 460 weight in reply to bm3501466 Is An Idiot!, 01-03-2007 11:57:12
66.90.73.19 you are clearly violating the respect rule of this forum. I do believe everyone else would agree that you are only hurting this website.
01-03-2007 12:34:31
 Re: farmall 460 weight in reply to bm3501466, 01-03-2007 12:04:40
129.137.28.188 you are a moron. You will have to go away before I ever will. Now go have another bowell movement and be amazed at how much it looks like a 350 or 1466 or yourself.
bm3501466
01-03-2007 12:45:24
 Re: farmall 460 weight in reply to bm3501466 Is An Idiot!, 01-03-2007 12:34:31
Why would you stick around longer than me? I find your potty jokes to be quite simple minded.
01-03-2007 13:26:01
 Re: farmall 460 weight in reply to bm3501466, 01-03-2007 12:45:24
You couldn`t find water if you fell out of a friggin boat. I will be here longer than you because I`m smater than you. You think I`m simple minded? Ok, you are a no minded moron. Therefore I`ll be here when you`re gone
bm3501466
01-03-2007 13:37:52
 Re: farmall 460 weight in reply to bm3501466 Is An Idiot!, 01-03-2007 13:26:01
Why do you think I am stupid?
01-03-2007 18:45:21
 Re: farmall 460 weight in reply to bm3501466, 01-03-2007 13:37:52
It`s better to let everyone think you`re stupid than to open your mouth and remove all doubt. You have opened your mouth and removed all doubt.
bm3501466
01-03-2007 18:52:11
 Re: farmall 460 weight in reply to bm3501466 Is An Idiot!, 01-03-2007 18:45:21
And you haven't?
01-03-2007 18:43:59
willywonka
01-01-2007 15:32:34
aluminum everything Ive even seen aluminum frame rails
willywonka Is An Idiot!
01-03-2007 11:58:16
 Re: farmall 460 weight in reply to willywonka, 01-01-2007 15:32:34
You are a chocolate moron.
Mr. Jerry LaGod
01-01-2007 15:01:58
Put that POS IH junk in the scrap heap where it belongs.
bm3501466
01-01-2007 18:55:10
 Re: farmall 460 weight in reply to Mr. Jerry LaGod, 01-01-2007 15:01:58
What's your problem Jerry? I've seen you make several similar trash comments. There may be tractor color disputes, but I don't think your comment showed much character to someone just wanting to know something.
Mr. Jerry LaGod
01-01-2007 19:31:45
 Re: farmall 460 weight in reply to bm3501466, 01-01-2007 18:55:10
I like your name, very fitting. Everytime I have a bowell movement I think of a trash POS IH 350 or 1466. Kinda fits your name don`t you think? b(owell)M(ovement)3501466. Nothing but I(gnorant)H(illbilly) junk. It should be scrapped.
MJF
01-01-2007 10:58:33
You could get an Alumminum floor plate and maybe a lighter radiator. I think I heard a while back that Chads had a 4000lb 460 but I'm not positive
ChadS
01-01-2007 13:07:49
 Re: farmall 460 weight in reply to MJF, 01-01-2007 10:58:33
Getting rid of the heavy upper bolster will get you alot lighter. That front end, with the pedistal is almost 400lbs!!! If the rules allow, build a custom wide front end out of tubing, or box tubing. Rigging up a POWER steering system is easy!!! My 460, with me on it is 3600lbs empty,,, I can get it alot lighter with aluminum parts, weld on hubs, light fenders, maybe a moon gas tank,top plate,,, I can see it in the 3300, 3400 lb range. Super M has seen my 460 upclose,,,, I think he liked what he seen. LOL! That front end is heavy!! Look at ways to lighten it up. Chad
super_m
01-01-2007 20:14:13
 Re: farmall 460 weight in reply to ChadS, 01-01-2007 13:07:49
oh ya chad,if you know anybody wantin one i've got the super m for sale.keepin the 460 lol
super_m
01-01-2007 19:50:10
would a tube wide front be legal for usap div2?how do you go about making one?
ChadS
01-02-2007 12:29:21
 Re: farmall 460 weight in reply to super_m, 01-01-2007 19:50:10
In Super Farm Stock classes, No, not allowed, Modified stock classes and up, Im pretty sure its allowed. My 460 has a custom front axle and it passed for 4mph and up type classes. I took 4x4 box tubing, with plates welded on the ends, with the frame bolt pattern in the plates, slid that piece in the frame rails. took 2 more 4x4 box tube pieces and welded them on the bottom of that, then welded the axle to the 2 pieces. Its not a floating axle, its solid rigid,,,, Im gonna change that someday,,,,, As for the axle itself,, I took an old wagon gear front steer axle,,, narrowed it up to the width I wanted, and welded it to the parts I described,,,, the whole front axle, with the tires, and steering cyl was only 175lbs total. Like I said, the stock front end is well,,,,, its a heavy SOB!!! LOL! 460's rock!! Chad
Super 9
01-01-2007 15:17:33
Does the top part of trans and bearings get the proper lube with no hyds. Thanks
Cody
01-01-2007 18:56:45
 Re: farmall 460 weight in reply to Super 9, 01-01-2007 15:17:33
first of all, start with a 300 or 350 rearend with TA delete. 300lbs lighter than a 460. Make you an aluminum top out of thin tubing, mine weighed 20lbs. disk brakes will help too.
