cam size
redkev
12-31-2006 21:34:50
I have a 1943 H can i put 350 cam in ?? where to get the 350 cam? need information thanks kev..
MJF
01-02-2007 07:50:28
 Re: cam size in reply to redkev, 12-31-2006 21:34:50
Hey chad I was going to get a new 450 cam but it has the M,SM,450 under one part number. I know they all fit but the grind specs are different. I held off on buying it because I wasn't sure what specs the used are they the 450 specs?
ChadS
01-02-2007 10:31:07
 Re: cam size in reply to MJF, 01-02-2007 07:50:28
The cams we have, are for M-450, but has the 450 grind on em with the left handed nut for live hyd pumps. I have them brand new if you need one,, Not a regrind. 574-893-7437. Chad
MJF
01-02-2007 17:03:09
 Re: cam size in reply to ChadS, 01-02-2007 10:31:07
How much is one of them new 450 cams, is that with or without a core. The only core I would have is my M cam
redkev
01-01-2007 20:25:18
I was told if could;t find 350 cam too grind the backside off my H cam would that be good??
ChadS
01-02-2007 10:26:38
 Re: cam size in reply to redkev, 01-01-2007 20:25:18
Id go junkyard shopping for a 350 cam before I would get into grinding the H cam. Chad
ChadS
01-01-2007 13:20:58
It will go right in! Im not sure if I can get new 350 cams, I know I can get new 450 cams,, Ill have to look,,,,, I dont know if this site has em, but Im positive they are outhere in "New" form. Chad
