Building an allis puller
SFH
12-31-2006 14:56:06
I am building a WD puller. I have got a couple of E Gleaner engines. I'm needing between 75 and 80 horsepower. I am wanting to pull between the 4000 and 5500 Superfarm class that is 3 1/2 mph and first gear only. Someone told me that you could offset grind the crank and put H Farmall rods in it but didn't know what piston to use. Any help would be greatly appreciated. I am just wanting to build a good dependable engine on a budget. Thanks.
sfh
01-03-2007 16:37:26
 Re: Building an allis puller in reply to SFH, 12-31-2006 14:56:06
By using a buda rod (I assume a 262 rod) what stoke should I expect,and also what piston can I use.
mbohio
12-31-2006 16:07:28
offset grind and buda rods
