Super M
wc
04-23-2002 18:22:23
I just built a super M with Dennys 4.125 piston kit and 450 lp head, manifold and cam. Will I have to run high octane fuel and how much HP should it have? Thanks WC
Tractor Junkie
04-30-2002 18:44:25
 Re: Super M in reply to wc, 04-23-2002 18:22:23
I have seen Dennys advertise 4 1/4 piston kits has anyone used them?
David H. Ransom
04-25-2002 16:50:56
You built your Super M? All new parts? Wow!
Flyin Farmall
04-24-2002 21:42:35
did you use the LP cam or one of Denny's?is the lp cam ground any different?
wc
04-25-2002 13:53:14
 Re: Re: Super M in reply to Flyin Farmall, 04-24-2002 21:42:35
I had the cam out of the super M ground at a local machine shop for a little more lift.I was told that the cam from a super M and 450lp were the same.
farmall flogger
04-24-2002 07:38:23
I'd want 100 octane with that kind of compression. Oughta be good for 60-65 horses. Should make a nice motor.
BUD BARENIE
05-03-2002 06:22:18
 Re: Re: Super M in reply to farmall flogger, 04-24-2002 07:38:23
JUST DID THE SAME THING !!! ONLY USED USED TISCO PISTONS !!!!! AND A WHOLE BUNCH OF HEAD WORK !!!! 12 HOUR ON THE MOTOR !!! NO LP !!
HEAD !!! PUT IT ON THE DYNO !!! (BANG) BLEW RITE THROUGH 58 HORSE ROCKED UP TO 64 !!! AND STILL HAD ALOT LEFT !!!!! LET HER COOL OFF !!!
AND HAD A BEER !!!! GOOD LUCK !!! NO SUCH THING AS AN LP CAM !!!! ALSO THERE ARE ALOT BETTER GRINDS THAN A 45O CAM !!!!! NEED MORE FUEL AND AIR !!!! DO ANY PORTING !!!!
how much did that cost.
04-24-2002 18:16:55
how much did it cost from denny's to get that done. I m getting ready to stroke my super m
wc
04-24-2002 18:43:33
 Re: Re: Re: Super M in reply to how much did that cost., 04-24-2002 18:16:55
The piston kit with total seal rings was $475.
