reduction gear part #
jdjack
12-26-2006 17:45:06
Want to change the reduction gear on a 44A to late model A. What is the part # of the gear that I need?
Are they all the same the? i have a gear that shows a3695r. Is that correct? Could somebody please post the correct Part # that i need.
Thanks JDJACK
JDMark
12-27-2006 04:55:41
 Re: reduction gear part # in reply to jdjack, 12-26-2006 17:45:06
jdjack, for the belt pulley you need gear A4030R and that can be pressed onto the belt pulley you have on your 44A or use the complete clutch set up of the late JDA. The first reduction gear you need is AA5442R. That will slow your tractor down about 26% Good Luck JDMark
52A
12-27-2006 11:30:07
 Re: reduction gear part # in reply to JDMark, 12-27-2006 04:55:41
Does that work both ways?? Will it speed up the late A? And will it be the same percentage?
DSK
12-26-2006 22:30:15
You have the right gear for the late A. The p.n. A3695R is actually the casting # of the spider.Part # of the assembly is AA5442R listed for A tractors 657393-up. The A12R spider & gear was used on earlier A's.
